Updated May 2025
Shadow Terminology
Device Shadow Service Document
The Device Shadow Service Document is a JSON document maintained by the Shadow service in the Amazon Web Services (AWS) cloud. It is used to store and retrieve current state information for a device.
Example document:
1{
2 "state" : {
3 "desired" : {
4 "color" : "RED"
5 },
6 "reported" : {
7 "color" : "GREEN"
8 }
9 },
10 "metadata" : {
11 "desired" : {
12 "color" : {
13 "timestamp" : 12345
14 }
15 },
16 "reported" : {
17 "color" : {
18 "timestamp" : 12345
19 }
20 }
21 },
22 "version" : 10,
23 "clientToken" : "UniqueClientToken",
24 "timestamp": 123456789
25}
Device Shadow Service Document Properties
A device's shadow service document contains the following properties:
  • state
  • desired
    The desired state of the device (thing). Applications can write to this portion of the document to update the state of a thing without having to directly connect to a thing. An example state as shown above is "color": "RED".
  • reported
    The reported state of the thing is the current state. A thing writes to this section of the document to report a new state.
  • metadata
    Information about the data stored in the
    state
    section, such as timestamps (in Epoch time) for each attribute in the
    state
    section. This enables you to determine when these sections were updated.
  • timestamp
    Indicates when the message was transmitted by AWS IoT. By using the timestamp in the message and the timestamps for individual attributes in the
    desired
    or
    reported
    section, a thing can determine how old an updated item is, even if it doesn't implement an internal clock.
  • clientToken
    A string which is unique to the device and that enables you to associate responses with requests in an MQTT environment.
  • version
    The document version is incremented with each document update. It is used to ensure the version of the document being updated is the most recent.
Shadow Update
A Shadow Update operation creates a device's shadow (if it doesn't exist), or updates the contents of a device's shadow service document. Any content change is stored with a timestamp to show when it was last updated. Messages are sent to all subscribers with the difference between the
desired
and the
reported
state (delta). Things or apps that receive these messages can perform an action based on the difference between the
desired
and
reported
states. For example, a device can update its state to the desired state, or an app can update its UI to show the change in the device's state.
Shadow Get
A Shadow Get operation retrieves the latest state stored in the device's shadow. For example, at startup, a device connects to AWS IoT Core to retrieve configuration data and the last state of operation. This method returns the full JSON document, including metadata.
Shadow Delete
A Shadow Delete operation deletes a device's shadow, including all of its content. This removes the JSON document from the database. Once a Device Shadow has been deleted, it can't be restored, but a new Device Shadow (with the same name) can be created.
Shadow Delta Callback
A Shadow Delta Callback returns the Shadow Delta State, a virtual state that contains the difference between the
desired
and
reported
states. Fields in the
desired
section that do not match the
reported
section are included in the Delta. Fields that are in the
reported
section and not in the
desired
section are not included in the delta. When a device's shadow is updated, and this results in a Shadow document with different
desired
and
reported
states, a message is published to the topic $aws/things/
thing-name
/shadow/update/delta.
This message contains only the difference between the
desired
and
reported
sections of the device's shadow document. Upon receiving this message, the device should decide whether to make the requested change. In the Shadow library, the delta state can be retrieved by registering a Shadow Delta Callback.
Shadow Updated Callback
A Shadow Updated Callback returns a state document to this topic from AWS IoT whenever an update to the shadow is successfully performed:
$aws/things/
thingName
/shadow/update/documents
The JSON document will contain two primary nodes:
previous
and
current
. The
previous
node will contain the contents of the full shadow document before the update was performed while
current
will contain the full shadow document after the update is successfully applied. When the shadow is updated (created) for the first time, the
previous
node will contain
null
. In the Shadow library, the updated state document can be retrieved by registering a Shadow Updated Callback.
